Ich bin wieder mal auf der Suche
Fuel and vacuum pump, series CF WO-647911
Spacer WO-647669, approx. 1/8" thick
Kann mir jemand helfen das Teil zu kriegen?
Caviglia Luzern hat's leider nicht mehr im Angebot
Helpful information
The CJ-3A, CJV-35/U and M38 utilize spacers between the fuel pump and the engine block. Over the years these spacers are often removed for various reasons. The CJ-2A style fuel pump is often retrofitted to these vehicles due to its lower cost. This is a fuel pump only, without the vacuum booster section. It does not require a spacer for proper operation. Lack of a spacer on the original CJ-3A, CJV-35/U and M38 fuel pumps can cause excessive fuel pressure. Fuel pressure can be lowered slightly by adding extra gaskets between the fuel pump and engine block.
a Link dazu http://www.cj-3a.com/Fuel%20Pumps.htm
Gruess aus der Schweiz
Claude :evil:
Danke für eure Hilfe
